Difference between 3002 4.0 and 4.1 software releases ?
pturton
I am in the process of upgrading a large number of 3002 Hardware clients and multiple 3030 concentrators.
They are all currently on version 4.0.1 software and I was wondering which would be the best version to upgrade to and what was the difference ?
On the download page there seems to be new releases of 4.0.x software and 4.1.x software for clients and concentrators ?
Any ideas what the difference is between the two, and which would be the best to go to ?
gfullage
The main thing that came out in 4.1 is WebVPN, but there were a few other new features included. The release notes for 4.1 are here:
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_1/41con3k.htm
Particularly read the New Features section.
If you're not interested in any of these features (the 3002 Save Password feature might be useful for you), then you may as well stay with the 4.0 release and try 4.0(5)A, since it simply includes bug fixes over the earlier 4.0 releases.
The release notes, detailing the bug fixes (Resolved Caveats) in each 4.0 release, are here:
http://www.cisco.com/univercd/cc/td/doc/product/vpn/vpn3000/4_0/405con3k.htm#wp307246
