01-02-2019 06:19 AM - edited 03-10-2019 01:08 AM
Hi Community,
We recently adquired a Cisco Prime's Solutions, it send us an email according security threats but also, send us a email about Interface down/up:
Message: Port 'GigabitEthernet1/0/3' (Description: 'Not available') is down on device '172.16.80.180'.
I'd like to disable that alerts, I configured the traps below:
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps snmp authentication linkup linkdown
snmp-server enable traps transceiver all
snmp-server enable traps tty
snmp-server enable traps license
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps cluster
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps energywise
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps power-ethernet police
snmp-server enable traps cpu threshold
snmp-server enable traps vstack
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps stackwise
snmp-server enable traps errdisable
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
Thanks in advance,
01-02-2019 06:31 AM
HI there,
You could configure the following on all access ports:
int x/x
no snmp trap link-status
no logging event link-status
It has been a while since I last used prime but you should also be able to tune out these alerts via the Alarm Policies.
cheers,
Seb.
