01-19-2005 12:20 AM - edited 03-09-2019 10:02 AM
Hi all ,
I have a queation about the PIX 515e problem , when i try to in DMZ win2000 server join a Inside AD domain is not work , i also try it full access list for this 2 ip address access below :
DMZ w2k server ip and access list :
access-list DMZ permit ip host 172.16.2.2 any
Inside 2003 server ip and access list :
access-list inside permit ip host 172.16.1.20 any
when i try to in DMZ server join Inside domain controller , the error message show can't establish the connection , what seen the problem and which port are need to open ? pls advise
Stanley
01-19-2005 02:05 AM
hello stanley,
If "IP any" is open, all ports are open from one side to another. u need not open any specific ports.
One thing you need to check is NAT. I hope you have done a static or a nonat from inside to dmz. otherwise, try doing this.
nat (inside) 0 access-list insidenonat
access-list insidenonat permit ip host 172.16.1.20 host 172.16.2.2
optional:
nat (dmz) 0 access-list dmznonat
access-list dmznonat permit ip host 172.16.2.2 host 172.16.1.20
By doing this, you can see both the servers on their private IPs. You will be able to ping these servers from each other. Are you able to ping now ??
you can also use statics:
static (inside,dmz) 172.16.1.10 172.16.1.10 netmask 255.255.255.255
You will still have the access-lists on place.. make sure you have applied the access-lists to the interface:
access-group insideACL(ACL name) in interface inside
access-list dmzACL in interface dmz
hope this helps.. all the best..
Raj
01-19-2005 05:45 PM
Hi Raj ,
Thanks for your help first ,but i try to your suggestion , i found that i can ping in both side for IP address , in hostname can't is timeout , also i add it the following acl and static
static (inside,dmz) 172.16.1.20 172.16.1.20 netmask 255.255.255.255
Is it add wins or dns need to config in my both server ???
Stanley
01-19-2005 11:01 PM
Hi Raj ,
The DMZ server can join the our domain now , thx
but i have a other problem is now i being open full port in between 172.16.2.2 and 172.16.1.20 these computer , i want to be limit the port , also i add it these access-list in my PIX is not , can't be login domain account , is it have any problem ?
access-list inside permit udp host 172.16.1.20 host 172.16.2.2 eq domain
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq domain
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq 88
access-list inside permit udp host 172.16.1.20 host 172.16.2.2 eq 88
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq 123
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq 135
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq ldap
access-list inside permit udp host 172.16.1.20 host 172.16.2.2 eq 389
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq 445
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq 3268
access-list inside permit tcp host 172.16.1.20 host 172.16.2.2 eq netbios-ssn
access-list inside permit udp host 172.16.1.20 host 172.16.2.2 eq netbios-ns
access-list inside permit udp host 172.16.1.20 host 172.16.2.2 eq netbios-dgm
access-list DMZ permit udp host 172.16.2.2 host 172.16.1.20 eq domain
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq domain
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq 88
access-list DMZ permit udp host 172.16.2.2 host 172.16.1.20 eq 88
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq 123
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq 135
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq ldap
access-list DMZ permit udp host 172.16.2.2 host 172.16.1.20 eq 389
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq 445
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq 3268
access-list DMZ permit tcp host 172.16.2.2 host 172.16.1.20 eq netbios-ssn
access-list DMZ permit udp host 172.16.2.2 host 172.16.1.20 eq netbios-ns
access-list DMZ permit udp host 172.16.2.2 host 172.16.1.20 eq netbios-dgm
I open it UDP/TCP 53 , UDP/TCP 88 , TCP 123 , TCP 135 , UDP/TCP 389 , TCP 445 , TCP 3268 , TCP 139 , UDP 137 & 138
Pls advise again, all the best
Stanley
