I'M UNABLE TO INSTALL THE VPN CLIENT 4.0.3 BECAUSE OF AN DNEINST EXECTION ERROR WHILE INSTALLING DNE, RETURN CODE 21-465000-93. DOES ANYONE HAVE A QUICK ANSWER? IF NOT, A SHOVE IN THE RIGHT DIRECTION WOULD WORK TOO. THANKS.
It seems that you are having problems installing the vpn cleint over an existing vpn client that already exits. I would recommend you to uninstall the DNE under the network and dialup connections also remove the TCP/Ip stack and then uintstall the network card as well. This should resolve the issue.
Learn, share, save
