DNS ISSUE
Roza12
Hi everyone
 i hope someone can help me with my problem
our customer network looks like :
stack core switches ---- routers ---- Firewall --- internet mpls----Firewall---- datacenter
in core switches 3 vlans are configured
1- vlan 16 for it.local
2- vlan 1 for dsvm
3- vlan 17
4- vlan 18 dmz  (new)
 they asked me to create new vlan in same way as the other vlans, after that they asked vlan 16 should talk see vlan 18
what i have configured in firewall :
1- Nat (VIP) port( http and tcp -8080)
2- ipv4 policy allowed source (all) to destination (VIP)
3- static route for the new range same way as others
4- from the vlans interface to trust interface allowed all -- all
what i achieved is :
1- i can ping from range vlan 16 to vlan 18 and the same for vlan 18
2- dns servers for all is in range vlan 16
10.50.16.31
10.50.16.32
3- i can ping from server in vlan 18 to these dns servers
4- i can telnet port 53 in vlan 18
the problem that i face right now
1- i cannot access any website/page when i use the dns servers although i can ping them
2- but when i change it to google dns everything is working properly
but this is not a good plan to keep it in public dns i have tried a lot to figure it out but without hope so can i get some help with that  ?
yalbikaw
hello :)
lets take it from the firewall.
1-now i know you allowed the ip communication but lets see logging,
if it ASA
enable logging and check the dns traffic or if there is any drops it will be logged for you.
2-try to use packet tracer to see the flow if its permitted.
3- packet captures if both options didnt isolate the problem
when you do the pcap make sure to do it for specific traffic and then check exactly what is happening.
thanks for your reply
i'm trying to access but i cannot we have some issues with our network
i can ping , telnet and the two vlans see each others put unknown dns server
what i understood from you the problem maybe with the firewall ??
The traffic is passing through the firewall correct
that's why I would like to check there and see what is happening
