Community Helping Community
104
Beginner
Downloadable IP ACLs problum..
Hi I am using PIX 525. I am using conduit and acl in inside interface. i am not using acl onoutside interface. Now I configured VPN users which are authenticated through RAIDUS ACS 3.2. I am using pix 6.3. Now normally VPN users are working fine because I configured conduit for those acs users. Now when I am using Downloadable IP ACLs for users. Now when users authenticate, dynamic ACL is applied on pix.but I am not able to access the system which I allowd in Downloadable IP ACLs. It's still check the conduit. Now which interace this dynamic acl is applied. Is I have to convert conduit int to acl to work with this configuration?
Mustafa
2 REPLIES 2
Rising star
Re: Downloadable IP ACLs problum..
Hi Mustafa,
It is a VERY good idea to convert your conduits to ACLs ! Convert the conduits to ACLs and see if you still have problems, remember to clear xlate after configuration.
Thanks - Jay.
Beginner
But if there is acl and conduit both in configuration, ACL should check first. Then why in this case it's check conduit, insted of acl?
Mustafa
Content for Community-Ad
FusionCharts will render here
