03-28-2004 11:06 PM - edited 03-09-2019 06:54 AM
I have two firewall blade in a Catalyst 6059.
I have associate one fireblade to 3 vlans with the following commands.
firewall module 8 vlan-group 50
firewall vlan-group 50 55-57
I need to configure the second fireblade as secondary in High Availability ditribution but when Iassign the same vlans to module 9 it says that only one svi can appear.
Someone knows how to configure to fireblade modules?
03-29-2004 03:51 PM
Follow the config guide and you should be OK:
Look at the "Setting up a Single-Chassis Configuration" section specifically.
03-31-2004 12:26 AM
I have seen the following command
failover lan interface if_name
Is this command in the router or in the firewall.
If I'm able to introduce this command, will the error message abou SVI disapear?
