Firewall connection with Switch
tayyab_ghauri
Is it necessary that a firewall connect to a switch using a 10/100 Mbps port or we can use any port for the connectivity. Give me reasons.
Thanks.
6 Replies 6
jzsides
You can connect to a 10 Mbps port, a 100 Mbps port, or a 10/100 Mbps port. If you have Gbps interface on your firewall you can connect to a Gbps port.
You can specify the speed of the interface in your firewall configuration.
mathia5
If you have a pix 501 then the inside 4 ports are 100 full only but the outside port is 10/100
It means firewalls does suppourt Gbps. Could you name any model having Gbps port?
Hi for the pix that support Gb, just go to the Cisco QRG:
http://www.cisco.com/warp/public/752/qrg/pdf/cpqrg_ch5_vpn_security.pdf
You have in this documents a matrix comparing pix hardware and support.
Marc.
davecs
hi,
in answer to your question - you can use whatever port you like.
ofcourse if you want to get full performance out of your network use the fastest possible.
ie it wouldn't be very smart to plug a PIX 535 into a 10 Mbit hub! :) but it would still work - just slowely!
cheers
dave.
