879
mirage__SK
Beginner
HELP!! Can not connect web server after DNS doctoring..
Dear All,
I have ASA 5510 version 8.2(5).
Network topology is following:
localnet  - 192.168.0.0/24
Servers - 192.168.1.0/24
Outside network.
www server has an address 192.168.1.1 and static NAT to public address 10.10.10.2
problem - client can not connect to server from localnet network.
I Use this document:
Perform DNS Doctoring with the static Command and Three NAT Interfaces Configuration Example
http://www.cisco.com/en/US/products/ps6120/products_configuration_example09186a00807968c8.shtml
after configuring when I try to ping web server from asa
write: ping www.some.com it returns echo reply correct, from private address... but I can not receive echo answer, when I try  to ping server from client pc (local network)...
here is my config:
hostname gw1
domain-name goletiani.ge
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 0p/CqCPqhGpaiy.f encrypted
names
name 10.10.10.2 www.some.com
interface Ethernet0/0
duplex full
nameif outside
security-level 10
ip address 10.10.10.1 255.255.255.24
interface Ethernet0/1
duplex full
nameif localnet
security-level 100
ip address 192.168.0.1 255.255.255.0
interface Ethernet0/2
duplex full
nameif servers
security-level 100
interface Ethernet0/3
duplex full
nameif others
security-level 100
ip address 192.168.25.1 255.255.255.0
interface Management0/0
nameif management
security-level 100
ip address 11.19.78.1 255.255.255.0
management-only
ftp mode passive
dns domain-lookup outside
dns server-group DefaultDNS
name-server 213.157.196.132
name-server 213.157.196.131
object-group service piblicInternetServices tcp
port-object eq 465
port-object eq 995
port-object eq www
port-object eq https
port-object eq pop3
port-object eq smtp
object-group service sipPublic tcp-udp
port-object eq sip
object-group service spiAllPublic udp
group-object sipPublic
port-object range 10000 20000
access-list admin_splitTunnelAcl standard permit 11.19.78.0 255.255.255.0
access-list localnet_nat0_outbound extended permit ip 11.19.78.0 255.255.255.0 11.19.200.0 255.255.255.240
access-list outside_access_in extended permit tcp any host 10.10.10.2 object-group piblicInternetServices
access-list outside_access_in extended permit icmp any 10.10.10.0 255.255.255.248
access-list outside_access_in extended permit ip any 10.10.10.0 255.255.255.248
access-list servers_access_in extended permit ip 192.168.1.0 255.255.255.0 any
access-list servers_access_in extended permit icmp 192.168.1.0 255.255.255.0 any
access-list others_access_in extended permit ip 192.168.25.0 255.255.255.0 any
access-list localnet_access_in extended permit ip 192.168.0.0 255.255.255.0 any
access-list localnet_access_in extended permit icmp 192.168.0.0 255.255.255.0 any
access-list others-limit-traffic extended permit ip 192.168.25.0 255.255.255.0 any
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu localnet 1500
mtu servers 1500
mtu others 1500
mtu management 1500
ip local pool AdminPool 11.19.200.2-11.19.200.14 mask 255.255.255.240
ip local pool Remote_Services 11.19.205.1-11.19.205.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (localnet) 0 access-list localnet_nat0_outbound
nat (localnet) 1 192.168.0.0 255.255.255.0
nat (others) 1 192.168.25.0 255.255.255.0
static (servers,outside) 10.10.10.3 sip.some.com netmask 255.255.255.255
static (servers,outside)10.10.10.2 www.some.com netmask 255.255.255.255 dns
access-group outside_access_in in interface outside
access-group localnet_access_in in interface localnet
access-group servers_access_in in interface servers
access-group others_access_in in interface others
route outside 0.0.0.0 0.0.0.0 212.72.141.81 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
aaa authentication serial console LOCAL
http server enable
http 11.19.78.0 255.255.255.0 management
http 10.10.10.0 255.255.255.0 servers
http 192.168.0.0 255.255.255.0 localnet
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec transform-set ESP-AES-256-MD5 esp-aes-256 esp-md5-hmac
crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac
crypto ipsec transform-set ESP-DES-MD5 esp-des esp-md5-hmac
crypto ipsec transform-set ESP-AES-192-MD5 esp-aes-192 esp-md5-hmac
crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac
crypto ipsec transform-set ESP-AES-256-SHA esp-aes-256 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-SHA esp-aes esp-sha-hmac
crypto ipsec transform-set ESP-AES-192-SHA esp-aes-192 esp-sha-hmac
crypto ipsec transform-set ESP-AES-128-MD5 esp-aes esp-md5-hmac
crypto ipsec security-association lifetime seconds 28800
crypto ipsec security-association lifetime kilobytes 4608000
crypto dynamic-map SYSTEM_DEFAULT_CRYPTO_MAP 65535 set transform-set ESP-AES-128-SHA ESP-AES-128-MD5 ESP-AES-192-SHA ESP-AES-192-MD5 ESP-AES-256-SHA ESP-AES-256-MD5 ESP-3DES-SHA ESP-3DES-MD5 ESP-DES-SHA ESP-DES-MD5
crypto map outside_map 65535 ipsec-isakmp dynamic SYSTEM_DEFAULT_CRYPTO_MAP
crypto map outside_map interface outside
crypto isakmp enable outside
crypto isakmp policy 10
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 86400
telnet 11.19.200.0 255.255.255.240 management
telnet timeout 5
ssh 192.168.0.0 255.255.255.0 localnet
ssh 11.19.11.0 255.255.255.0 servers
ssh timeout 15
console timeout 0
dhcpd dns 213.157.196.132 213.157.196.131
dhcpd lease 1800
dhcpd address 192.168.0.222-192.168.0.254 localnet
dhcpd dns 213.157.196.132 213.157.196.131 interface localnet
dhcpd enable localnet
dhcpd address 192.168.25.2-192.168.25.179 others
dhcpd dns 213.157.196.132 213.157.196.131 interface others
dhcpd enable others
dhcpd address 11.19.78.2-11.19.78.254 management
dhcpd enable management
threat-detection basic-threat
threat-detection statistics access-list
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy admin internal
group-policy admin attributes
vpn-tunnel-protocol IPSec
split-tunnel-policy tunnelspecified
split-tunnel-network-list value admin_splitTunnelAcl
username root password Xriu58Vv0BnOxFPD encrypted
tunnel-group admin type remote-access
tunnel-group admin general-attributes
address-pool AdminPool
default-group-policy admin
tunnel-group admin ipsec-attributes
pre-shared-key *****
class-map others-limit-traffic
match access-list others-limit-traffic
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map others-limit-traffic
class others-limit-traffic
  police input 20000 1500
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
service-policy others-limit-traffic interface others
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:10cf8cf0872531a1b572297712f944f5
: end
what's wrong?
0 REPLIES 0
Content for Community-Ad
