help with explanation of command "sh cry eng acc stat"
mpedro
Beginner
Beginner
I am troubleshooting a problem with our VPN network and I used the command "show crypto engine accelerator statistic". Does anybody know the link on CCO where it explains the output of this command in detail. I am most interested in what the "Alerts:1" output means
194220rt001#sh cry eng acc stat
Encryption AIM in aim slot: 0
ds: 822EF798 idb: 822ECE68
Statistics for Encryption Module:
207329 packets in 207329 packets out
100681 packets decrypted 106648 packets encrypted
51580884 bytes decrypted 13109648 bytes encrypted
55205400 bytes before decrypt 16948976 bytes after encrypt
13 paks/sec in 13 paks/sec out
29 Kbits/sec decrypted 9 Kbits/sec encrypted
0 packet overruns
rx_no_endp: 0 rx_hi_discards: 0 fw_failure: 0
invalid_sa: 0 invalid_flow: 0 cgx_errors 0
fw_qs_filled: 0 fw_resource_lock:0 lotx_full_err: 0
null_ip_error: 0 pad_size_error: 0 out_bound_dh_acc: 0
esp_auth_fail: 0 ah_auth_failure: 0 crypto_pad_error: 0
ah_prot_absent: 0 ah_seq_failure: 0 ah_spi_failure: 0
esp_prot_absent:0 esp_seq_fail: 0 esp_spi_failure: 0
obound_sa_acc: 0 invalid_sa: 0 out_bound_sa_flow: 0
invalid_dh: 0 bad_keygroup: 0 out_of_memory: 0
no_sh_secret: 0 no_skeys: 0 invalid_cmd: 0
dsp_coproc_err: 0 comp_unsupported:0 pak_too_big: 0
null packets: 0
pak_mp_length_spec_fault: 0
tx_lo_queue_size_max 0 cmd_unimplemented: 0
14997 seconds since last clear of counters
Interrupts: 395982 Immed: 3 HiPri ints: 205873
LoPri ints: 190210 POST Errs: 0 Alerts: 1
Unk Cmds: 0 UnexpCmds: 0
cgx_cmd_pending:0 packet_loop_max: 0 packet_loop_limit: 0
Michael
beth-martin
Contributor
Contributor
I searched Cisco's site and came up with nothing detailed on that alert. It's probably a good idea to tell Cisco's tac about it though when you're troubleshooting this with them.
Recognize Your Peers
