How to activate ADSM 5.0F on FWSM SW 3.1.1
v.kreisel
Beginner
Beginner
I have installed SW 3.1.1 on my FWSM.
The documentation says that ADSM 5.0F is included in 3.1.1.
(http://www.cisco.com/en/US/partner/products/hw/modules/ps2706/products_data_sheet0900aecd803ded77.html).
Because I couldn't find/activate ADSM 5.0F I copied ADSM 5.1(1) on the FWSM which seams to work well.
Any idea about getting ADSM 5.0F installed/running ?
Volker
varakantam
Beginner
Beginner
ASDM 5.0F is not available yet and maybe available in the next few weeks. 5.1(1) is not a fully supported configuration I beleive.
Hello. I am also running my FWSM's on 3.1 and I made the mistake of assuming that ASDM 5.0F was part of the image. I have multiple contexts which are managed by individuals with little or no command line experience.
When can I expect to see ASDM 5.0F available?
-MP
Hello. Same question here!
What are your experiences with the new release? Any problems regarding the update/daily business?
regs, Sam
w.haslam
Beginner
Beginner
When I try to copy ASDM 5.1(1) to flash:asdm I get an error message "Detected legacy ASDM version" and wont save. I had the PDM on there before which I believe is causing the problem. How can I get rid of it if I am using the 3.1.1 fwsm image?
Recognize Your Peers
