498
Highlighted
Beginner
how to configure dot1x to check for mac address then to send to radius
hi,
is there any way on a switch to get a port to check a list of mac addresses then if the pc is not in that list send the request to a radius server. the radius we use is steelbelt radius.
cheers
tony
1 REPLY 1
Highlighted
It looks you are looking for the mac authentication bypass (MAB) feature.
Please take a look at the feature in detail:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/sw8021x.html#wp1205506.
You can authenticate devices based on MAC address.
Here is a step guide to configure it on older IOS releases:
http://preview.cisco.com/en/US/docs/solutions/Enterprise/Campus/IBD/MACAuthB.html.
12.2(50) and later IOS:
http://www.cisco.com/en/US/partner/docs/switches/lan/catalyst3750/software/release/12.2_52_se/configuration/guide/sw8021x.html#wp1196845.
HTH,
Tiago
If  this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
Content for Community-Ad
