How to delete IP logs?
kendo.igor
I'm using a Cisco IDS 4235. It's running version 4.1. How can I delete the IP logs on the sesnor that I no longer need. Is there a way to purge or delete the IP logs?
Thanks.
marcabal
Version 4.1 does not support the ability to delete IP Logs manually.
The IP Logs are stored in what can be considered a circular buffer of 512MB. When the buffer is full and a new IP Log is triggered then the new IP Log will automatically overwrite the oldest IP Log.
