i have fmc as vm that is controlling two ftd 2110 in HA , thing is thousands of users are using it and it is very critical, besides taking backup of the fmc what other things i can check and do to keep it healthy?
FMC as a VM is cheap.. If its critical, you can setup another one and put them in HA. I always increase the memory and CPU depending on what version you started with that may be low as well..
Learn, share, save
