i have 3 groups of users and want to do the following:-
Group 1 onto vlan 1
Group 2 onto vlan 2
Croup 3 onto vlan 3
do i use 802.1x and radius or is there another way to achieve this.?
cheers
tony
Hi Tony,
Vlan assignment via RADIUS would be a good option to achieve this.
In case users do not have a dot1x supplicant, you may also want to consider MAB to still be able to authenticate them via RADIUS and assign vlans.
Alternatively, for non-dot1x capable users, you could also look into th guest vlan feature, but this won't allow you to differentiate vlans: it'll use the same vlan for all guest users.
Fede
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
