03-15-2005 05:28 PM - edited 03-09-2019 10:38 AM
Hi, there.
I have a problem for anomaly detector.
I shut down detector unusually and then an error occurred during the booting process. The error messages are the following.
Checking root filesystem
/ contains a file system with error, check forced.
Unattached inode 96194
/: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a ro -p option )
*** An error occurred during the file system check.
*** Dropping you to a shell; the system will reboot
*** when you leave the shell.
Give root password for maintenance
(or type Control-D for normal startup) : ????????
What's the root password for maintenance?
Let me know the above. Help me, please.
Best Regards,
from ALEX
03-18-2005 09:23 AM
Is this any help..
http://www.cisco.com/en/US/products/ps5887/products_password_recovery09186a008037942b.shtml
Jeremy.
05-20-2006 01:03 PM
Does this procedure supports the V5.03 version as well? We are trying out the product; and need to do some diagnostics. Don't seem to get the prompt to select the image for single user login. Hope you can help.
Thanks.
