I need your help
rzcisco
hi engineers ,
i setup IDS along with CSPM ,managed them and configure proper host IDs and ORG IDs and so on .
i think everything is ok ,i can ping the sensor .
but i cann't touch what is sensed in my database ,it is always empty with only three lines ,the last one is "route up "
any comment ,mostly appreciated !
thanks
jeff.k
If you have connectivity (i.e. seeing the route up), it may just be that you haven't told the sensor what interface to sniff on.
In CSPM, do a File>Save&Update. Then, go to the Command Tab, and do an "approve now" to push your config out to the sensor.
See the following doc for more details/troubleshooting:
Configuring a Cisco Secure IDS Sensor in CSPM
http://www.cisco.com/warp/public/707/ids2cspm_6117.html
Jeff
thank u very much ,
at least you said some word .
ciao
