IDS 4210 config problem
leungpokit
Beginner
Beginner
I try to change the config. of the sensor by use sysconfig-sensor command.
After I use the "Communciations Infrastruction" and try to save the config. ,the sensor says :
cp: cannot create /usr/nr/etc/eventd.conf: Read-only file system
ERROR: Could not create /usr/nr/etc/eventd.conf
I have find our tutor to fix this problem, however, they also do not understand what were happening.
Who can help me to solve this problem?
Thx~
kleem
1. Make sure that permissions.ownership of all the files in the /usr/nr/etc directory is "-rw-r----- 1 netrangr netrangr".
2. Run sysconfig-sensor as root
We run sysconfig-sensor as root and try to write the 777 permissions to the file, however, the system do not allow us to do that.
Moreover, it do not allow us to change the permissions of this file.
That's why all our staff feel strange!
Why are you trying to change the permissions to 777? Have you made other modifications to the sensor? Probably the quickest solution would be to use your 'Recovery CD' and reimage the sensor.
After you have done this, do not make any changes to the permissions on any files. Image your sensor and run 'sysconfig-sensor' as root. No other modifications are required.
Chris
Recognize Your Peers
