IDS 4215 Monitoring Problem On Cisco 2950 Switch
smartin
On my Cisco 2950 Switch I enabled SPAN to enable me to scan all internal traffic
(monitor session 1 source interface Fa0/1
monitor session 1 destination interface Fa0/2)
Fastethernet0/1 is connected to PIX E1
Fastethernet0/2 is connected to Cisco IDS Scan port
I have several Windows 2000 servers on this switch. On one of the servers I run Backup Exec which does a backup on the servers on the switch.
Everthing works great until the backup job kicks off.
At that time the switch itself fails.
When I disable SPAN the backup job & the switch itself works OK.
Any help would be greatful.
drolemc
Level 6
Level 6
I could not find any bugs describing such issue. The only thing that I can think of is that the server is pumping data too fast and overwhelming the switch. I guess, if you are able to reduce the speed at which data is handed over to the switch, SPAN and backup might work together.
