IDS system
yv
No offense to cisco, but its solution for ids is very expensive!
what other non expensive products are considered to be best of the best?
thomas.chen
Level 6
Level 6
Actually, there are a variety of Cisco solutions at various price-points. I usually start lower end installations with the 4210. It is capable of monitoring up to 45-50Mbps and it includes both the IDS software and the hardware to run the application. Last time I checked, ISSand Axent both sell their software-only systems for 10% more money And you’d still have to buy the PC, the Operating System, and assemble the pieces. There’s a public domain solution called "Snort" but understand you don't get any support or regular/predictable updates.I’d also be concerned about relying on public domain technology for your company's security protection. I like having a company that backs their products and provide support that I can rely on. Good luck with your decision.
net.admin
Checkout Symantec (former Raptor stuff) and NAI.
Certain IOS routers can also run a limited IDS built into the IOS with FW/IDS feature set.
I suppose it depends on what you need to accomplish with your security policy.
Scott
