Community Helping Community
240
Beginner
IIS 6 and PIX 501
I'm sorry I posted this on the wrong board.
I have a cable modem that plugs into my PIX 501. I'm running 6.3(1) on the PIX.
How do I go about creating a NAT to allow outside [specifically my work office] to connect to the web server I have at my house?
I added these two lines to the config on my PIX:
static (inside,outside) xxx.xxx.xx.xx xxx.xxx.x.xx 255.255.255.255 [this one to NAT the outside INT of the cable modem to the invalid IP of the web server]
and this rule to test it [I added this rule the tried to access the web server from my work]:
access-list 101 permit tcp any host xxx.xxx.xx.xx eq www
When I "wr mem", I can't browse out from my internal network and I can't get to my website from outside.
4 REPLIES 4
Frequent Contributor
Re: IIS 6 and PIX 501
static (inside, outside) tcp interface www 1.2.3.4 www netmask 255.255.255.255
forwards port 80 from the outside interface to the port 80 in inside host 1.2.3.4
Beginner
I still can't get it to work. All I want to do is setup a website behind the PIX. I'm using IIS 6.0 behind the PIX 501. I using a cable modem and use the
outside interface IP I get from the cable modem folks. [It's DHCP]
Here is a copy of my config from the home pix:
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable passwordxxxx
passwd xxxx
hostname homepix
domain-name xxxxxx.com
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list 101 permit tcp any host xx.xx.xx.xx eq pptp
access-list 101 permit gre any host xx.xx.xx.xx
access-list 102 permit tcp any host xx.xx.xx.xx eq www
pager lines 24
logging on
logging host inside 192.168.1.10
logging host inside 192.168.1.12
logging host inside 192.168.1.19
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm location 192.168.1.10 255.255.255.255 inside
pdm location 192.168.1.12 255.255.255.255 inside
pdm location 192.168.1.19 255.255.255.255 inside
pdm location 192.168.1.2 255.255.255.255 inside
pdm location 10.10.11.0 255.255.255.192 outside
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (inside,outside) tcp xx.xx.xx.xx www 192.168.1.15 www netmask 255.255.2
55.255 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-pptp
telnet 192.168.1.2 255.255.255.255 inside
telnet 192.168.1.12 255.255.255.255 inside
telnet 192.168.1.19 255.255.255.255 inside
telnet timeout 5
ssh timeout 5
console timeout 0
vpdn username Lane password ********
vpdn enable outside
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:xxx
homepix#
you do not have an access group command that binds the access lsit to the outside interface
Highlighted
Beginner
Thanks!
Content for Community-Ad
FusionCharts will render here
