A PC uses the inside interface of the pix as default gateway. Therefore, the PC sends his remote packets to the pix. The pix has a static route to send the packets back via the inside interface to a next hop router. This does not work, because the pix always wants packets to flow between different interfaces.
Is there a workaround or should my pc definitly use another default gateway?
Edgar
