IP spoof
john-kelsey
I get the critical alert.
Deny IP spoof from (192.168.97.16) to virtual_plc on interface outside
Which I understand because both addresses are on the same subnet, yet on different interfaces.
However I would like them to communicate, how do I do that please?
I have attached a drawing of the network.
We VPN into our customer's site, where the VPN server gives us the 192.168.97.x address.
The customer's network is 151.133.100.x where our router is at 151.133.100.80.
We static NAT 151.133.100.81 and 151.133.100.81 thru to 192.168.100.180 and 192.168.100.184 respectively.
Our router is an ASA5505
Thanks in advance.
John
Ah ha, you have no default route defined.
route outside 0.0.0.0 0.0.0.0 x.x.x.x
x.x.x.x = inside ip of the other ASA that you are vpn'ing into.
11 Replies 11
acomiskey
Level 10
Level 10
Which firewall in the diagram are you vpn'ing to?
The first one - NOT the ASA5505 on the slicer
What is the subnet mask of the slicer inside network? You could try to disable it with
no ip verify reverse-path interface outside
The Inside subnet mask is 255.255.255.0
I will try this when I get to work tomorrow.
I added the - no ip verify reverse-path interface outside
Now though, I get the error
Failed to locate egress interface for TCP from outside:192.168.97.x
How do I get back from the slicer network to the VPN's?
Could you post the config from your ASA?
Here is the conf file
Thank you for your help, I am now back at home - I shall try that first thing in the morning.
John.
Thank you acomiskey.
Adding route outside 0.0.0.0 0.0.0.0 x.x.x.x resolved the issue.
However, supposedly it brought down the customers network, does this sound possible?
John.
could it be multicast-routing, it was not enabled yesterday?
