01-21-2019 09:33 AM - edited 02-21-2020 09:32 PM
I apologize if this is posted in the wrong location. I'm standing up an IPSEC tunnel between two sites. Eventually all sites will use the head end as a backup connection. The tunnel establishes but I'm not seeing an OSPF adjacency nor can I ping the IP of the tunnel on either side. I see that the head end is receiving packets but isn't responding. The route for the far end IP appears to be correct on the head end. I don't see anything else wrong, no errors. Any ideas?
Solved! Go to Solution.
01-23-2019 04:08 AM
01-22-2019 01:35 PM
On the farend router you should modify the configuration as follows:-
interface tunnel 1
no tunnel destination
tunnel mode gre multipoint
You may also want to add "ip ospf hello-interval 30" on each router's tunnel interface.
01-22-2019 01:49 PM
I made the changes.....same result as before.
01-22-2019 01:52 PM
01-22-2019 04:15 PM
Interesting as you can see on the head end there isn't any dmvpn information. But the far end shows peer information.
Headend:
Farend:
01-23-2019 03:36 AM
01-23-2019 04:05 AM
I have a duplicate thread. Made a rookie mistake posting in two different places. Here is the link to the other thread. Updated configs are attached.
https://community.cisco.com/t5/routing/routing-over-gre-ipsec-tunnel/m-p/3785459#M308139
01-23-2019 04:08 AM
01-23-2019 04:08 AM
01-23-2019 04:19 AM
tunnel mode gre multipoint was already configured but I did remove the key on both ends and now I have an OSPF adjancy. Thank you very much.
Farend tunnel config:
interface Tunnel1
bandwidth 20000
ip address 10.192.0.254 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp authentication VCbh1q93
ip nhrp map multicast dynamic
ip nhrp network-id 1
ip nhrp holdtime 600
ip nhrp redirect
ip policy route-map VPN-Internal
ip ospf network broadcast
ip ospf priority 2
ip ospf mtu-ignore
delay 1000
tunnel source GigabitEthernet0/0/1
tunnel protection ipsec profile vpnprof
Head end tunnel config:
interface Tunnel1
bandwidth 20000
ip address 10.192.0.17 255.255.255.0
no ip redirects
ip mtu 1400
ip nhrp map 10.192.0.254 111.111.111..237
ip nhrp map multicast 111.111.111.237
ip nhrp holdtime 300
ip nhrp nhs 10.192.0.254
ip ospf priority 2
delay 1000
tunnel source GigabitEthernet0/0/0
