Highlighted
Beginner
ISE installation with VMWare Error..
Hi All,
i install ISE version : 1.1.1.268, I installed ISE on VMWare Version 5.1,  in Installation process, ISE check the Network and NTP , but fail.
and this step i skip, and then process installation is going normal until finish.
after installation finish, i try ping from console ISE to network gateway and ntp server but error is come out:
"% Error : Error invoking ping for the provided host"
In attachment i show VMware configuration
Anyone can help me please?
3 REPLIES 3
Beginner
Re: ISE installation with VMWare Error..
Does your ISE have any network connectivity? Can you ping the gateway?
Beginner
Thats the problem, i think problem is Vmware not the ISE.
Enthusiast
I am giving you the installation guide for ISE on VMware and Esxi server. Please follow the steps, i have done my installation using this guide only.
http://www.cisco.com/en/US/docs/security/ise/1.0.4/install_guide/ise104_vmware.html
