Key regeneration in switches
gaattila
Once I genereate rsa keys in the 3560 switch, they are regenerated in every 60 minutes automatically. During the process the cpu utilizition goes up to 40-50%.
Is there a way to change the period at which the keys are regenerated, or to disable this feature?
The switch is running the latest IOS release.
Attila
smalkeric
Level 6
Level 6
We can?t change regeneration period in switches, you can disable this feature. Check this link, it might help you
http://www.cisco.com/en/US/tech/tk583/tk617/technologies_tech_note09186a0080094314.shtml
Thanks for your reply. I see that I can disable ssh, but can I disable the key regenaration only, while enabling ssh?
Attila
