I will be doing small PoC to customer for manual Macsec between 2 switches. I have Cisco 3650 switches with the below image .
cat3k_caa-base.SPA.03.07.02E Macsec supports on this image
below is the configuration on two switches
SW1
interface GigabitEthernet1/0/1
switchport mode access
switchport nonegotiate
cts manual
no propagate sgt
sap pmk 0000000000000000000000000000000000000000000000000000001234ABCDEF mode-list gcm-encrypt
end
SW2
cts manual
no propagate sgt
end
After configuring it i can only able to see the SC encrypt packets but decrypt byte is unchanged and remains 0
Is there any other way to verify that Macsec is running fine? and can i use SPAN to show the traffic is encrypted?
Appreciate your quick response on this
below is the out put of the show command
DC-SW2#sh macsec interface gigabitEthernet 1/0/1
MACsec is enabled
Replay protect : enabled
Replay window : 0
Include SCI : yes
Use ES Enable : no
Use SCB Enable : no
Admin Pt2Pt MAC : forceTrue(1)
Pt2Pt MAC Operational : no
Cipher : GCM-AES-128
Confidentiality Offset : 0
Capabilities
Identifier :
Name :
ICV length : 16
Data length change supported: yes
Max. Rx SA : 16
Max. Tx SA : 16
Max. Rx SC : 8
Max. Tx SC : 8
Validate Frames : strict
PN threshold notification support : Yes
Ciphers supported : GCM-AES-128
Transmit Secure Channels
SCI : 00FEC84304010000
SC state : notInUse(2)
Elapsed time : 01:01:25
Start time : 7w0d
Current AN: 0
Previous AN: 1
Next PN: 0
SA State: notInUse(2)
Confidentiality : no
SAK Unchanged : no
SA Create time : 05:36:15
SA Start time : 7w0d
SC Statistics
Auth-only Pkts : 0
Auth-only Bytes : 0
Encrypt Pkts : 2649
Encrypt Bytes : 0
SA Statistics
Auth-only Pkts : 0
Encrypt Pkts : 174
Port Statistics
Receive Secure Channels
SCI : CC46D6ECC4810000
Start time : 7w0d
Current AN: 0
Previous AN: 1
Next PN: 0
RX SA Count: 0
SAK Unchanged : no
SC Statistics
Notvalid pkts 0
Invalid pkts 0
Valid pkts 2176
Valid bytes 0
Late pkts 0
Uncheck pkts 0
Delay pkts 0
UnusedSA pkts 0
NousingSA pkts 0
Decrypt bytes 0
SA Statistics
Notvalid pkts 0
Invalid pkts 0
Valid pkts 52
UnusedSA pkts 0
NousingSA pkts 0
Port Statistics
