MACsec on Catalyst 9300
OJ_Magellan
I have read the follwoing in Cisco Security Config guide  regarding MACsec on the Catalyst 9300 (IOS XE 17.3.x):
  • MACsec is not supported on Locator ID Separation Protocol (LISP) interfaces and Cisco Software-Defined Access (SD-Access) solution.
when is it going to be supported?
OJ
yes inside fabric not supported.
BB
balaji.bandi
what is the use case here ?
In General MACsec required when you connecting to Switch to switch, where security concern on Layer 2 connectivity.
SD-Access totally Macro and Micro segemented based on the Policy deployment.
BB
OJ_Magellan
Hi BB,
Switch to Switch in a SD environment, in the Guide it says that MACsec is not supported in SDA Solution as I mentioned above. Is this still the case?
OJ
BB
