05-06-2021 05:19 AM
I have read the follwoing in Cisco Security Config guide regarding MACsec on the Catalyst 9300 (IOS XE 17.3.x):
when is it going to be supported?
OJ
Solved! Go to Solution.
05-10-2021 10:34 AM
yes inside fabric not supported.
05-06-2021 05:38 AM
what is the use case here ?
In General MACsec required when you connecting to Switch to switch, where security concern on Layer 2 connectivity.
SD-Access totally Macro and Micro segemented based on the Policy deployment.
05-10-2021 12:57 AM
Hi BB,
Switch to Switch in a SD environment, in the Guide it says that MACsec is not supported in SDA Solution as I mentioned above. Is this still the case?
OJ
05-10-2021 10:34 AM
