MACSec possible with IEEE 802.1Q Tunneling ?
kerstin-534
Use Case:
To use MACSec between 2 Catalyst 3560-X on both sides with a provider network between that is configured for
Since MACSec uses 0x88e5 Frames and the Cisco SAP protocol uses 802.1x for negotiation, can that be
working ?
(I haven't success)
As there anybody who can confirm it can work and it how is done, please tell me.
best regards,
Herbert
Eduardo Garcia
Yes, you need a device that can tunnel 802.1x via L2PT.
L2PT is not needed in EoMPLS as all control packets pass untouched, this is why EoMPLS works.
Hello Eduardo,
reading the config guide of the Nexus 7k
http://www.cisco.com/en/US/docs/switches/datacenter/sw/5_x/nx-os/interfaces/configuration/guide/if_qinq_tunnel.html#wp1091505
this sounds like the Nexus 7k would tunnel the 802.1x frames as soon as I switch on
interface ethernet xxx
switchport mode dot1q-tunnel
l2protocol-tunnel
Is that true? Or does any other Cisco Device  tunnel 802.1x via L2PT? For example the metro switches?
Thank you!
   Thorsten
That Nexus is only capable of tunneling CDS, STP and VTP.
EoMPLS tunnels all (e.g. 802.1x) without modification to the destination mac-address.
