MARS Reporting: Resource Usage
tech_trac
I have added 20+ devices to MARS successfully. However, when I view the Resource usage report (i.e. CPU, Memory etc) I only see 10 devices and in some case only couple. Why doesn't the report list all the devices.
Secondly, is it possible to view the bandwidth in bits per sec and can the report be extracted in form of a table with relevant values against specific time intervals.
Thanks.
drolemc
Level 6
Level 6
MARS does not discover L2 devices automatically as it does with L3 devices. Ensure all the devices are reachable or not. And also check the configuration and the logs.
http://www.cisco.com/en/US/docs/security/security_management/cs-mars/6.0/user/guide/combo/cfgOver.html#wp363870
