Memory leak
kiksen1
Dear Forum,
I just bought the 831 Image
c831-k9o3sy6-mz.123-4.T2.bin to do DMVPN. Everything
works fine, but after one or two days the router
runs out of memory. I observed this problem with
sh proc memory and the memory is decreasing every hour a little bit more.
What can I do?
02-09-2004 20:40:14 Local7.Critical 10.7.7.254 7334: -Process= "NHRP",
ipl= 0, pid= 96
02-09-2004 20:40:14 Local7.Critical 10.7.7.254 7333:
02-09-2004 20:40:14 Local7.Critical 10.7.7.254 7332: Alternate Pool:
None Free: 0 Cause: No Alternate pool
02-09-2004 20:40:14 Local7.Critical 10.7.7.254 7331: Pool: I/O Free:
8228 Cause: Memory fragmentation
02-09-2004 20:40:14 Local7.Critical 10.7.7.254 7330: 22:56:09:
%SYS-2-MALLOCFAIL: Memory allocation of 4680 bytes failed from
0x800EEA7C, alignment 4
%ALIGN-3-TRACE: -Traceback= 8055CA3C 80562ABC 80563988 80563AD4
805648C4 8016B8EC 801700B8 00000000
02-09-2004 20:39:47 Local7.Error 10.7.7.254 7315: 22:55:43:
%ALIGN-3-SPURIOUS: Spurious memory access made at 0x8055CA3C reading
0x34
02-09-2004 20:39:16 Local7.Critical 10.7.7.254 7314: -Traceback=
80176C14 80177E14 800EEA80 800EEF6C 800EFC1C 800F1CC4 80562174
80562584 80563970 80563AD4 805648C4 8016B8EC 801700B8
02-09-2004 20:39:16 Local7.Critical 10.7.7.254 7313: -Process= "NHRP",
ipl= 0, pid= 96
Best,
Christian
jsivulka
Level 5
Level 5
To troubleshoot memory related problems, you could refer to 'Troubleshooting Memory Problems' at http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6f3a.shtml.
