MM_WAIT_MSG2
aksher
Beginner
Beginner
On L2L VPN tunnel, I am getting "MM_WAIT_MSG2" through pahse 1 checking command "sh crypto isakmp sa" for a specific tunnel which is not up. What can be the possible debugging which can be done?
owillins
Frequent Contributor
Disconnection of the tunnel is caused by a network issue, we need to configure DPD (DeadPeerDetection) to make sure that whenever one side of the connection goes down, the other side realises about the disconnetion and restarts the tunnel.
How do you enable DPD? is it for a specific VPN tunnel or all tunnels?
Recognize Your Peers
