Webcast- Catalyst 9000
8880
Beginner
Mount USB stick on an ASA 5505?
I have an ASA 5505 and the built in flash is pretty small and I need to put 3 .pkg on it for Anyconnect 4.
I formated an USB Stick (4GB) to FAT32 and put in the USB Port 2 on the back and rebooted the firewall.
But in the filemanager I see disk0 and disk1, but disk1 does not work, doesn't list anything and I can't create folders on it.
Can I mount the USB stick manually or something?
Kind Regards.
1 ACCEPTED SOLUTION
Hall of Fame Master
The USB port on the 5505 is
The USB port on the 5505 is not a supported file storage location.
On the newer 5500-X series (including the 5506-X) you can do that.
3 REPLIES 3
Hall of Fame Master
Beginner
Oh, I see, that sucked. Well,
Oh, I see, that sucked. Well, then I'll have to replace the flash memory.
Highlighted
Beginner
Re: The USB port on the 5505 is
One wonders why then that Cisco put three of them on the 5505.
