Highlighted
Beginner
Multicast Configuration for Symantec Ghost
Hello Everyone:
I am having problems correctly configuring my PIX to support the multicast traffic required by Symantec Ghost Console.
My intended Symantec Ghost Console functionality:
Ghost is used to manage/refresh Windows 2000 computers in Hotel Business Center and Lobby*
Ghost Console Server = internal network, member of internal Domain
Ghost Target Workstations = DMZ network, members of "Public" workgroup
* These computers are used to access the Internet and perform local computing functions. They have no access to the "internal" network.
My configuration:
Ghost Console server:
IP = 192.168.0.18
Default Gateway = 192.168.0.75 (PIX Inside interface)
Workgroup\Domain = SJH Domain
PIX Interface = Inside
Ghost Target Workstation:
IP = 192.168.2.31
Default Gateway = 192.168.2.1 (PIX DMZ interface)
Workgroup\Domain = SJHPublic Workgroup
PIX Interface = DMZ
PIX, multicast-related configuration:
multicast interface dmz
forward interface inside
multicast interface inside
mroute 192.168.0.18 255.255.255.255 inside 229.55.150.208 255.255.255.255 dmz
The problem is that, alothough the Ghost Client installs correctly, the client is not "visible" to the Ghost Console -- even though I can open up Windows shares on DMZ workstation from the Console server. Symantec has answered a question similar to mine as follows: "If the Ghost Console and Ghost Clients aren't able to communicate with one another across the WAN, then some network device
is blocking the connection. If you are unable to determine which device is filtering multicast ..."
Does my PIX multicast configuration appear to be correct?
I'm going to throw this question at Symentc as well.
Thanks to all for you input,
Alan
1 REPLY 1
Highlighted
Contributor
Re: Multicast Configuration for Symantec Ghost
As far as I know, there is some minimum PIX OS version required for pix to work with Multicast, I am not sure if it is 6.1 or 6.2, you could check that.
