Highlighted
Beginner
NAC and SSO Doubts
I'm new here and am having a doubt.
I configured the NAC to do SSO with Microsoft AD. The user make login into the domain and the NAC Agent finds your credentials without problems.
When we make login on the local computer, the NAC agent requests credentials.
If I enter the credentials of the user's domain, occur a authentication error.
If I enter the credentials of the user created on CAM, the authentication pass with successful.
Is this normal or i'm makeing something wrong?
Tks
Daniel Stefani
Everyone's tags (7)
4 REPLIES 4
Rising star
Re: NAC and SSO Doubts
AD SSO only works with domain credentials, and not the local user credentials.
HTH,
Faisal
If you find this post helpful, please rate so others can find the answer easily
Beginner
Hi Faisal,
Thanks for responding quickly,
But the situation is different from what you understand.
First I login with the local credentials in the station that is not in the domain.
Then comes a pop up of Nac Agent requesting credentials.
At the moment I enter the credentials of the domain and then the authentication error occurs.
I think that to work, I need to set the option to choose the Authentication Provider.
am I right?
Tks Again
Daniel Stefani
Rising star
Daniel,
That's what I was explaining. If you have your agent set to do AD SSO, then you need to login to the Windows Domain, and not to your local computer. If you're logging in to your local computer and want to authenticate the agent to AD, you'll have to define a LDAP auth provider and enable that in your login pages.
HTH,
Faisal
Beginner
Thanks again Faisal,
I'll do it.
Sincerely,
Daniel Stefani
