01-31-2011 07:23 AM - edited 02-21-2020 04:14 AM
I have installed a NAC Manager and a NAC server in OOB with no problems, but when i configured the HA (high availability) with another server, my ASA and several hosts in my network started working ant 100% of cpu.
I have tried configuring every nac interfaces on a single DMZ, and the problem stills there.
Does anyone had this issue (NAC version 4.7)
TKX
Miguel Amaral
Solved! Go to Solution.
02-02-2011 03:15 AM
Hello Miguel,
When I was starting an InBand NAC HA solution I had a similar problem that I solved configuring the HA heartbeat to use just ETH0 instead of using ETH0 and ETH1.
Best Regards
Luciano Carvalho
02-01-2011 02:11 AM
It looks you have a loop...
Can you share with us the switches configuration where the CASes are connected?
Can you show us the network diagram showing the connections between the CASes?
HTH,
Tiago
If this helps you and/or answers your question please mark the question as "answered" and/or rate it, so other users can easily find it.
02-01-2011 03:01 AM
Hi Tiago!!
I will get that information to you, but i will add that all interfaces are on diferent vlan's, but even if i only have the trusted interface connected, i get this problem. As soon as i disconnect all the interfaces from both servers the network stabilizes. Before i configured the HA, everything was working fine, with both truted and untrusted interfaces.
Miguel
02-02-2011 03:15 AM
Hello Miguel,
Best Regards
Luciano Carvalho
