NAT from DMZ to outside
itomercateo
i need some help on PIX515e, which i'm quite a newbie on and i dont want to kill any running service ...
I need a kind of NAT from the DMZ to the outside.
There is one Mailer in the DMZ which has to bee seen on the outside with a fixed routable IP.
Should i use the nat or the static command for this ?
Can someone please tell me how to do this or where to RTFM ?
Thanks!
regards
Jörg
mhussein
Level 4
Level 4
See the configuration example:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a008015efa9.shtml
Basically, if the firewall is up and running, you would need to add 2 lines of configuration, a "static" command, and an access-list entry. From the example:
static (dmz,outside) 209.164.3.5 172.16.128.103 netmask 255.255.255.255
access-list smtp permit tcp any host 209.164.3.5 eq smtp
Where:
smtp= access-list name
209.164.3.5 = public ip address
172.16.128.103 = private ip address
Keep in mind that you need to find out the name of the access-list that is already configured on the firewall. The name of the access-list above just happened to be "smtp" - the name has no significance. To find out what the access-list name should be, check your firewall for a line similar to:
access-group acl_name in interface outside
Please let us know if that helped
Mustafa
Thanks for your answers.
I have seen this link you mention before, but i thought this example would only establish a portforwarding from the Outside to the machine in the DMZ.
Does this "static" command also means, that connects from the server in the DMZ to the Outside gets source nat ?
I mean, does the pix give every outgoing connection from this server the same (with "static" defined) source ip ?
regards
Jörg
Yes, this is a one-to-one translation; connections from the server will be source nat'd.
Port forwarding is different, and can be configured:
static (dmz,outside) tcp 209.164.3.5 smtp 172.16.128.103 smtp netmask 255.255.255.255
