I am receiving this error when attempting to connect to my 1720 router using
version 3.5.1 on the Cisco VPN client
4 22:25:52.330 06/13/02 Sev=Warning/2 IPSEC/0x6370001E
Unexpected TCP control packet received from 64.69.121.18, src port 2200, dst port 2804, flags 14h
I'm not sure what Inside local IP address I should use in the
ip nat inside source static tcp command. Right now all of may Inside local IP address are pointing to an AS400.
