NBAR port 80 P2P
jmessina
Will NBAR with the latest pdlm be capable of recognizing traffic on port 80 that is p2p like kazAa and differentiate between that and HTTP?. In other words can I rate limit and/or Drop P2P applications functioning on port 80 and not effect HTTP? Most documnetation suggests "deep packet inspection" and recognizing statefulness but i was curious if anyone knows if this is reliable.
Thank you for any feedback.
j-block
Level 4
Level 4
Most of the control traffic is encrypted except for the ones that go over the regular http port 80. Most of the bandwidth hog is the data traffic and not the control traffic. The Kazaa2 pdlm classifies the traffic by looking for a Kazaa specific string within the Kazaa Data Traffic - regardless of the port number used.
Here is a sample config:
match protocol http url *topsearch* - for the control traffic on port 80
match protocol http host www.cms1.net - control traffic on port 80
match protocol http host *kazaa* - control traffic on port 80
match protocol kazaa2 - data traffic
match protocol fasttrack - data traffic
