4239
Beginner
need HA license for ASA5516
Do i need to buy HA license for ASA5516-K9 or ASA5516-FPWR-BUN-K9?
or it comes built in.
Mitesh
1 ACCEPTED SOLUTION
Hello Mitesh-
Hello Mitesh-
HA comes with the base license for the 5516-X. Only the 5506 and the 5512 require the Security Plus license to get HA enabled. For more info please reference the following link:
http://www.cisco.com/c/en/us/td/docs/security/asa/asa95/configuration/general/asa-95-general-config/intro-license.html#ID-2148-00000a6e
I hope this helps!
Thank you for rating helpful posts!
3 REPLIES 3
Hello Mitesh-
Hello Mitesh-
I hope this helps!
Highlighted
Hall of Fame Master
Like Neno said for the base
Like Neno said for the base ASA.
Note that if you are using the FirePOWER module, those are licensed per unit - even in an HA pair.
So you would have to but the L-5516-<URL/TA/TAC/TAM/TAMC>-<1Y/3Y> as appropriate.
Beginner
Re: need HA license for ASA5516
Below is my BOM, do I need to add License to both the device or the license quantity would be one fo both. I mean in HA mode.
ASA5516-FPWR-BUN ASA 5516-X with FirePOWER Svcs. Chassis, Subs, FireSight Mgr --- N/A 0.00 1
ASA5516-FPWR-K9 ASA 5516-X with FirePOWER services, 8GE, AC, 3DES/AES --- 21 5,995.00 2
CON-SNT-ASA556F9 SNTC-8X5XNBD ASA 5516-X with FirePOWER services, 8GE 12 N/A 988.63 2
