Need help making a 1720 more secure??
emance
I am doing some work for a client that has a 1720. IOS 12.1
I just noticed that I can telnet in from home. How can I make this more secure? How can I tell if this unit has the VPN package? How do I view the firewall settings?
Thanks for your help,
Eric
Your image is C1700-O3Y-M. This means you have the IP/FW feature set. This feature set does include the IOS firewall but not VPN.
Sigurbjartur
5 Replies 5
bfl1
Eric... here are 2 good links to router security. The one on the NSA's home page also has other security features. The router files are about 1/2 way down the page.
http://psyber.letifer.org/downloads/priv/cis-2.pdf
http://www.nsa.gov/snac/index.html
ghent
To control who can telnet into the box, you need to create an ACL which defines which source IP can telnet into the box and then you need to associate the ACL with the vtys.
! ACL to control telnet access
! Only permit telnet access from the 192.168.2.0/24 network
access-list 23 permit 192.168.2.0 0.0.0.255
line vty 0 4
! ACL associated with the vtys
access-class 23 in
And now only those specified by ACL 23 can telnet into the box. Instead of the Network/Wildcard you can use 'access-list 23 permit host 192.168.2.20' to allow a single host.
VPN?
The 'show version' command should yield a line that's something like :
"IOS (tm) C1700 Software (C1700-K9O3SY7-M), Version 12.3(1), RELEASE SOFTWARE (fc3)"
The C1700-K9O3SY7-M tells you which features are included in the software. If you see the letters 'k2' the software has VPN with 3DES encryption and if you see '56i' it has VPN with 56bit DES encryption.
If your software contains the IOS firewall feature (CBAC) you can view it's configuration using the following command:
sh ip inspect [ all | config | interfaces | name | sessions [detail]]
Sigurbjartur
Here is my version info:
IOS (tm) C1700 Software (C1700-O3Y-M), Version 12.1(5)T10, RELEASE SOFTWARE (fc
2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Wed 08-Aug-01 02:34 by ccai
Image text-base: 0x800080E0, data-base: 0x806F02F4
ROM: System Bootstrap, Version 12.0(3)T, RELEASE SOFTWARE (fc1)
Duct&Vent uptime is 41 weeks, 2 days, 15 hours, 31 minutes
System image file is "flash:c1700-o3y-mz.121-5.T10.bin"
cisco 1720 (MPC860) processor (revision 0x601) with 24576K/8192K bytes of memory
Processor board ID JAD053308VL (1149039308), with hardware revision 0000
M860 processor: part number 0, mask 32
Bridging software.
X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
1 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
Eric
Sigurbjartur
Thank you for your reply.
This helps me alot,
Eric
