08-03-2008 02:44 PM - edited 03-09-2019 09:13 PM
Very standard EZVPN configuration...
EZVPN clients can connect with the server (871 router) and they can ping the router however they can't ping computers inside the LAN but these computers can ping EZVPN clients without problems. Somebody please help! Thanks!
version 12.4
no service pad
hostname CCSPHOMERTR
boot-start-marker
boot-end-marker
enable secret xxx
aaa new-model
aaa authentication login LOGIN_AUTHEN local
aaa authorization console
aaa authorization exec EXEC_AUTHOR local
aaa authorization network NETWORK_AUTHOR local
aaa session-id common
crypto isakmp policy 100
encr aes
hash md5
authentication pre-share
group 2
crypto isakmp client configuration group EZVPN_GROUP
key XXXXXXXX
dns 10.0.0.254
domain pc-pro.ca
pool IPPOOL_EZVPN
acl ACL_EZVPN_SPLIT
crypto ipsec transform-set IPSEC_TRANS_EZVPN esp-aes esp-md5-hmac
crypto dynamic-map EZVPN_DYNAMIC_MAP 1
set transform-set IPSEC_TRANS_EZVPN
reverse-route
crypto map VPN_MAP client authentication list LOGIN_AUTHEN
crypto map VPN_MAP isakmp authorization list NETWORK_AUTHOR
crypto map VPN_MAP client configuration address respond
crypto map VPN_MAP 65535 ipsec-isakmp dynamic EZVPN_DYNAMIC_MAP discover
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.3
ip dhcp excluded-address 10.0.0.254
ip dhcp pool VLAN10_IP_POOL
network 10.0.0.0 255.255.255.0
default-router 10.0.0.254
dns-server 10.0.0.254
domain-name pc-pro.ca
ip dhcp pool VISTA_IP_POOL
host 10.0.0.3 255.255.255.0
client-identifier 0100.1a92.d12a.de
no ip bootp server
ip domain name pc-pro.ca
username support privilege 15 secret xxx
archive
log config
hidekeys
ip ssh rsa keypair-name RSA_SSH
interface FastEthernet0
switchport access vlan 10
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
ip address dhcp
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip virtual-reassembly
ip route-cache flow
duplex auto
speed auto
crypto map VPN_MAP
interface Vlan1
no ip address
interface Vlan10
ip address 10.0.0.254 255.255.255.0
ip nat inside
ip local pool IPPOOL_EZVPN 10.255.255.1 10.255.255.253
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list ACL_NAT interface FastEthernet4 overload
ip nat inside source static tcp 10.0.0.2 22 interface FastEthernet4 2222
ip access-list extended ACL_EZVPN_SPLIT
permit ip 10.0.0.0 0.0.0.255 10.255.255.0 0.0.0.255
ip access-list extended ACL_NAT
deny ip 10.0.0.0 0.0.0.255 10.255.255.0 0.0.0.255
permit ip 10.0.0.0 0.0.0.255 any
control-plane
line con 0
exec-timeout 60 0
login authentication LOGIN_AUTHEN
no modem enable
line aux 0
line vty 0 4
exec-timeout 60 0
logging synchronous
transport input ssh
scheduler max-task-time 5000
webvpn cef
end
08-03-2008 06:45 PM
change ur split tunnel to the following
Access-list 10 permit ip 10.0.0.0 0.0.0.255
should work now now
then
acl 10
good luck
Please, if helpful Rate
08-04-2008 12:10 AM
Thank you for your quick reply! However it still doesn't work...
Here is my config now:
key XXXXXXXX
dns 10.0.0.254
domain pc-pro.ca
pool IPPOOL_EZVPN
acl 1
access-list 1 permit 10.0.0.0 0.0.0.255
By the way the standard access-list can't specify "ip" in the list. It's the not the problem, right?
I don't think the split-tunneling works because after the connection the client doesn't show the "secured routes" to 10.0.0.0. Instead it shows 0.0.0.0 255.255.255.255, just like no split tunneling at all. I also tried no split tunneling but it doesn't work too... Please advice. Thanks!
08-04-2008 06:08 AM
do the following
keep the split tunnel ACL as i told u i mean the new one
first change the client pool to
ip local pool IPPOOL_EZVPN 10.200.200.1 10.200.200.253
then change the nating as follow
ip nat inside source route-map NATING interface FastEthernet4 overload
route-map NATING permit 10
match ip address ACL_NAT
deny ip 10.0.0.0 0.0.0.255 10.200.200.0 0.0.0.255
about the ip in the spilt tunnel dont worry
do as i told u befor simple standerd one
and let me
good luck
08-04-2008 09:55 AM
key XXXXXXXX
dns 10.0.0.254
domain pc-pro.ca
pool IPPOOL_EZVPN
acl 1
route-map ROUTE_MAP_NAT permit 10
Still don't work... The split tunneling standard ACL doesn't seem to work. Please see the attachment. Anyway the split tunneling shouldn't be the problem, right? Even without the split tunneling it still won't work...
However if I use "tracert" I do get reply from the router (10.0.0.254) but no further reply. It seems like the router itself doesn't know how to forward the ping...
Please help! Thanks!
08-04-2008 01:05 PM
I just tried an extended ping on the router. I specified the source interface as F4 (external interface) and pinged an internal IP 10.0.0.3 and it couldn't go through. Is that normal? Normal ping works...
CCSPHOMERTR#ping
*Aug 4 20:58:30.420: %SYS-5-CONFIG_I: Configured from console by support on consol
Protocol [ip]:
Target IP address: 10.0.0.3
Repeat count [5]:
Datagram size [100]:
Timeout in seconds [2]:
Extended commands [n]: y
Source address or interface: fastethernet 4
Type of service [0]:
Set DF bit in IP header? [no]:
Validate reply data? [no]:
Data pattern [0xABCD]:
Loose, Strict, Record, Timestamp, Verbose[none]:
Sweep range of sizes [n]:
Sending 5, 100-byte ICMP Echos to 10.0.0.3, timeout is 2 seconds:
Packet sent with a source address of 70.64.22.2
Success rate is 0 percent (0/5)
CCSPHOMERTR#ping 10.0.0.3
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
08-04-2008 05:10 PM
hi dear
keep the config as i told and as u have dont after change
only one thing i want u to change it
the split tunnel
this one i have just tried it and its working
acce-list 100 permit ip 10.0.0.0 0.0.0.255 any
then
go to ur vpn group configuration
do
no acl 10
then
acl 100
and let me know
by the way make an loopbak interface any try to ping it after u change the split tunnel to acl 100
good luck
08-04-2008 06:27 PM
Still the same... I don't think it's because of split-tunneling. I should be able to ping the internal network even without split tunneling.
key XXXXXXXX
dns 10.0.0.254
domain pc-pro.ca
pool IPPOOL_EZVPN
acl 101
access-list 101 permit ip 10.0.0.0 0.0.0.255 any
08-04-2008 07:10 PM
then fix the router problem
and now ur vpn config should be fin
good luck
if u need any more help just post here
please, if helpful rate
