12-26-2002 05:38 AM - edited 03-09-2019 01:30 AM
Dear VPN3000 Expert,
I am having problem with Netmeeting connetion from a VPN Client that is terminated an IPSec tunnel to a VPN3000 Concentrator. This VPN Client`s Netmeeting peer is a PC behind the Concentrator. I already read the FAQ about VPN3000, it says that a Netmeeting will not work with a VPN client, but it doesn`t have any detail reason why Netmeeting won`t work with an encryption tunnel. The explanation is very bad that I really doesn`t understand the meaning. If anyone can make a better explanation why Netmeeting will not work with an IPSec tunnel would be very appreciated.
And does anyone know if Netmeeting will be supported from a VPN client ?
Best Regards,
Engel
Solved! Go to Solution.
12-26-2002 11:04 AM
Engel,
Netmeeting, I believe uses H323, which the VPN client does not support. The h323 support will be there in version 4.0 of the client
Jazib
12-26-2002 11:04 AM
Engel,
Jazib
12-26-2002 04:36 PM
Hi Jazib,
Thanks, I will tell the end-client to wait until version 4.0. Do you have any information on estimate date of VPN client v4.0 release ?
Best Regards,
Engel
12-26-2002 07:50 PM
Hi Engel,
Sometime in April - May 2003 time frame. It's a tentative date, so don't quote me on that :~)
Jazib
