No Internet connection pix501 behind nated dsl
ptr609
I have a pix501 v6.2 and am trying to get an internet connection. The idea is to setup a (lan to lan) 501 to 3005 concenrator. I want to use ezvpn at the 501 but the problem is that I cannot get a internet connection if I actually get the dhcp ip address 192.168.1.2 from the 501. It's fighting with the dsl on dhcp. Somtimes on the client computer I get the address from the pix sometimes I get the address from the dsl (192.168.254.2). If I get the address from the dsl I get the internet but thats no good for vpn'ing. I'm assuming its a nat problem with the pix or an access list problem. The dsl is not static at the public address. Any pointers would be greatly appreciated! I'll be the first to admit I'm not very good at this! I have however established many client vpn connections to the 3005.
here is the pix config as it stands right now.
: Written by enable_15 at 03:49:46.677 UTC Tue May 27 2003
PIX Version 6.2(2)
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password xxxx encrypted
passwd xxxx encrypted
hostname ourhostname
domain-name ourdomain.com
fixup protocol ftp 21
fixup protocol http 80
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol sip 5060
fixup protocol skinny 2000
names
pager lines 24
interface ethernet0 10baset
interface ethernet1 10full
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
no sysopt route dnat
telnet timeout 5
ssh timeout 5
dhcpd address 192.168.1.2-192.168.1.33 inside
dhcpd lease 36000
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
vpnclient vpngroup langroup password xxxxxxx
vpnclient username lanuser password xxxxxx
vpnclient server 63.160.211.3
vpnclient mode network-extension-mode
vpnclient enable
terminal width 80
Cryptochecksum:xxxx
: end
sampathsr
I have done this before for my previous company. I am not sure how you have connected the various devices. Here is what i did:
computers----->switch----->PIX 501---->DSL modem---->co-ax cable from ISP
1. This way the computers would get DHCP addresses only from the PIX.
2. The caveat is that since the public IP address assigned to the outside interface of the PIX could be changing every time you re-boot the DSL modem (for whatever reasons!), your peer on the other side might have to keep changing the peer IP address.
But for that it works great.
Best regards / Sampath
Srengarajan@att.com
Thanks for the response but the issuse is really in getting to the internet from the pix while getting a address from the pix.
computers-pix501-dsl-internet
Right now I'm only trying to connect one computer, later there will be a switch.
cant get from the private to the public on the pix. I know the gateway of the dsl just not the public address.
Hi:
Your configuration looks perfectly okay to me.
Please try the following:
1. Connect the PC to the DSL modem directly and browse to ensure that from that point everything is fine.
2. If the above works, reboot the modem and the PC after making all the required connections.
3. When it is booting up, (console in through the 'console' port ) when the command 'ip address outside dhcp setroute' is executing, look for any error.
4. Once it boots up without any error, do a 'show ip address' and ensure that the outside interface has a valid public IP address.
5. Ensure that the PC is able to get a dynamic address and you are able to ping the inside interface of the PIX.
My guess is the rebooting should do the trick!
Best regards / Sampath.
I really thank you for your time on this! I have thought about this and now know why its not working or may never work. The dsl is sending the pix a private dhcp address and natting that to its public address. The pix is sending the client its dhcp address and the dsl is not natting that range. So the public address on the DSL is 170.216.16.215 sending a 192.168.254.2 to the pix the pix is sending a 192.168.1.2 to the client and that is not going to work. I think there is no way around this except to accept the fact that without changing the DSL nat this is not going to work. The dsl people say they cant change the nat Hey thanks alot for your help you are right on the money with looking at the outside interface address.
