No translation group found for icmp src outside
gspencer
Hi All,
Can someone assist with this issue. I must be overlooking something, so I'm here.
I have a server connected on the outside of my PIX520. I can start a connection from the inside to the server. But from the server to the inside, I cannot start a connection.
Here's a sample config and the error message I'm receiving.
I tried a few things with nat and static commands but none works. Thanks in advance.
BTW this firewall isn't a public facing firewall.
access-list inbound permit ip any any
access-list inbound permit icmp any any
access-list inbound permit icmp any any echo-reply
ip address outside 10.20.7.13 255.255.255.0
ip address inside 172.20.103.15 255.255.255.0
failover ip address outside 10.20.7.14
failover ip address inside 172.20.103.16
global (outside) 1 10.20.7.20-10.20.7.30 netmask 255.255.255.0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
static (outside,inside) 172.20.125.195 10.20.7.32 netmask 255.255.255.255 0 0
access-group inbound in interface outside
route inside 0.0.0.0 0.0.0.0 172.20.103.10 1
route outside 172.20.125.192 255.255.255.224 10.20.7.13 1
609001: Built local-host inside:172.20.103.11
305009: Built dynamic translation from inside:172.20.103.11 to outside:10.20.7.30
609001: Built local-host outside:10.20.7.32
305009: Built static translation from outside:10.20.7.32 to inside:172.20.125.195
302013: Built outbound TCP connection 22 for outside:10.20.7.32/23 (172.20.125.195/23) to inside:172.20.103.11/15361 (10.20.7.30/15361)
305005: No translation group found for icmp src outside:10.20.7.32 dst inside:172.20.103.15 (type 8, code 0)
rsmith
Level 3
Level 3
Because you are attempting access from a lower security interface to a higher, and NAT is enabled, unless there is an established session (translation) from the inside, you will not be able to access the inside network.
One option is to use a network NAT, "static (inside,outside) 172.20.103.0 172.20.103.0 netmask 255.255.255.0"
A better way would be to use NAT (0), "nat (inside) 0 172.30.103.0 255.255.255.0" This will keep the same inside IP address across the firewall to the outside interface.
Thanks for the suggestion. That worked. Is there a shorter command that would specify several subnets at the same time. Or can you point me to the documentation.
Thanks again.
GS
hello.
I have the same problem. I try to access through a vpn connection to the internal network (192.168.0.0) but when I used the option:
static (inside, outside) 192.168.0.0 192.168.0.0 netmask 255.255.255.0 "
The Internet connection has been dropped.
excuse my English.
