1877
robbhanMid
Beginner
No translation group found
I get the following error message when I try to connect over a site-to-site VPN:
No translation group found for tcp src outside:10.10.10.2/1038 dst inside:192.168.1.22/80
How do I set up the asa so that all traffic coming from 10.10.10.2 gets properly translated and can travel the inside hosts on 192.168.1.0?
thanx
My config:
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
ip address 10.10.10.1 255.0.0.0
interface Vlan3
nameif dmz
security-level 50
ip address 192.168.200.1 255.255.255.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
switchport access vlan 3
interface Ethernet0/6
interface Ethernet0/7
passwd xxx
ftp mode passive
dns server-group DefaultDNS
domain-name *
access-list http_access_in extended permit tcp any any eq www
access-list dmz_access_in extended permit icmp 192.168.200.0 255.255.255.0 192.168.1.0 255.255.255.0
access-list dmz_access_in remark Specify what kind of trafic should be allowed to travle to the inside network
access-list dmz_access_in extended permit tcp host 192.168.200.2 192.168.1.0 255.255.255.0 eq www
access-list NO-NAT extended permit ip any 192.168.200.0 255.255.255.0
access-list ftp_access_in extended permit tcp any any eq ftp
access-list 8080_access_in remark Specify what kind of trafic should be allowed in. Don't forget the NAT
access-list 8080_access_in extended permit tcp any any eq www
access-list l2l_list extended permit ip 192.168.1.0 255.255.255.0 192.168.100.0 255.255.255.0
pager lines 24
logging enable
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-603.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 0 access-list NO-NAT
nat (inside) 1 0.0.0.0 0.0.0.0
nat (dmz) 1 0.0.0.0 0.0.0.0
static (dmz,outside) tcp interface ftp 192.168.200.2 ftp netmask 255.255.255.255
static (dmz,outside) tcp interface 8080 192.168.200.2 8080 netmask 255.255.255.255
static (dmz,outside) tcp interface www 192.168.200.2 www netmask 255.255.255.255
access-group 8080_access_in in interface outside
access-group dmz_access_in in interface dmz
route outside 192.168.100.0 255.255.255.0 10.10.10.2 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout uauth 0:05:00 absolute
dynamic-access-policy-record DfltAccessPolicy
http server enable
http 192.168.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec transform-set FirstSet esp-3des esp-md5-hmac
crypto map abcmap 1 match address l2l_list
crypto map abcmap 1 set peer 10.10.10.2
crypto map abcmap 1 set transform-set FirstSet
crypto map abcmap interface outside
crypto isakmp enable outside
crypto isakmp policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
no crypto isakmp nat-traversal
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
dhcpd address 192.168.1.20-192.168.1.99 inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
tunnel-group 10.10.10.2 type ipsec-l2l
tunnel-group 10.10.10.2 ipsec-attributes
pre-shared-key *
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
message-length maximum 512
policy-map global_policy
1 ACCEPTED SOLUTION
ASA1
access-list NO-NAT extended permit ip 192.168.1.0 255.255.255.0 192.168.200.0 255.255.255.0
ASA2
access-list NO-NAT extended permit ip 192.168.200.0 255.255.255.0 192.168.1.0 255.255.255.0
5 REPLIES 5
a.alekseev
Rising star
What is 10.10.10.2?
Oh! maybe I wasn't clear enough.
10.10.10.2 is the outside interface of the other asa whos computers on its inside network needs to communicate with inside clients on this asa.
check "nat (inside) 0" on another ASA.
I have nat (inside) 1 0.0.0.0 0.0.0.0
on both my asa's. Is this correct?
ASA1
ASA2
Content for Community-Ad
