Not able to configure SSH
mkarthick
I'm using 1841 router.My question is I'm not able to configure SSH in this router ,Any IOS problem?
Sh version
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(1c), RELEASE SO
FTWARE (fc1)
Hi Karthick
You are currently running IP BASE Feature Set ios on your router you need to upgrade the same to Advanced Security Services or SP Services Feature set to have SSH support in your router..
http://www.cisco.com/en/US/products/sw/iosswrel/ps5460/index.html
regds
PAUL TRIVINO
Level 3
Level 3
You *probably* need to generate the keys - try
crypto key generate rsa
It will ask how long a key, use at least 1024 for most ssh clients.
When you're done it will say "ssh 1.99 enabled" or something.
Paul
Oops! Just noticed your sh ver - I don't think IPBASE doe it, you need IP with crypto.
Hi Paul,
Thanks for your reply
Should i upgrade my IOS? could u plz explain to me .
Karthick.M
Hi Karthick
regds
Any ideas on what that upgrade would cost?
