10-24-2005 08:50 AM - edited 03-09-2019 12:48 PM
FTP not working, data channel not getting set up.
I did an outside capture and can see that although the inside addresses are being translated, and the control channel getting set up, when a PORT command is issued, the IP address in the command is the inside IP.
The server then responds with a
Response: 500 I won't op
10-24-2005 10:51 AM
Do you have fixup protocol ftp enabled? Where is the PIX in this config?
10-24-2005 12:25 PM
This actually is an ASA, running version 7. Fixup is now "inspect" and is supposed to be enabled by default. I.e. I have no explicit FTP configuration.
The ASA is the Internet firewall.
