03-08-2004 04:44 AM - edited 03-09-2019 06:40 AM
During the setup of the NIDS version 4 sensors, the following questions are asked.
Could you help by giving the correct answers for each of these questions if the sensor is located in Brussels, Belgium?
Modify system clock settings?[no]: yes
Use NTP?[yes]:
Modify NTP Server?[no]: yes
NTP Server IP Address[x.x.x.x]:
NTP Key ID[1]:
NTP Key Value[1]:
Modify summer time settings?[no]: yes
Recurring, Date or Disable?[Recurring]:
Start Month[apr]:
Start Week[first]:
Start Day[sun]:
Start Time[02:00:00]:
End Month[oct]:
End Week[last]:
End Day[sun]:
End Time[02:00:00]:
DST Zone[CET]:
Offset[60]:
Modify system timezone?[no]: yes
Timezone[CET]:
UTC Offset[60]:
Solved! Go to Solution.
03-08-2004 04:09 PM
From what I can gather for Brussels (checked from http://www.timeanddate.com/worldclock/city.html?n=48) you should need the following:
Use NTP?[yes]:
NTP Key ID[1]: 1 (can be anything if you NTP server does not require authentication)
NTP Key Value[1]: 1 (can be anything if you NTP server does not require authentication)
Recurring, Date or Disable?[Recurring]: Recurring
Start Month[apr]: March
Start Week[first]: last
Start Day[sun]: sun
Start Time[02:00:00]: 02:00:00
End Month[oct]: Oct
End Week[last]: last
End Day[sun]: sun
End Time[02:00:00]: 03:00:00
DST Zone[CET]: (Not sure about this field I think it's just a nametag for your timezone)
Offset[60]: 60 (Since your clock settings will add an hour during daylight savings)
Timezone[CET]: (Not sure about this field I think it's just a nametag for your timezone)
UTC Offset[60]: 60 (Since Brussels is UTC+1)
03-08-2004 04:09 PM
Use NTP?[yes]:
Start Day[sun]: sun
End Month[oct]: Oct
End Day[sun]: sun
